Custom 3D model using scripting PYTHON
Dear ALL,
I have enquiry about scripting Python to created pipe support. I try sample scripting from others model to test at catalog builder. When i open at Plant 3D, the model/object not appear.?
How to import scrpting at PLANT 3D.
Best regards,
Anuar
dave.wolfe
Did you use PLANTREGISTERCUSTOMSCRIPTS?
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
I did when i want to upload my script at catalog builder. Can you give advise for the process to do it.?
Hi mr wolfe,
I try your process guide for scripting python for Plant 3D, but i got some problem in scrpting. Can you advice me please. I attached my scrpting file and file directory. Can you explain for varmain import what's mean of that.?
I done do it add arxadapter, registerscript and test script shortcut at tool pallete.
#import aqa.math
#import math
#from varmain.primitiv import *
#from varmain.var_basic import *
#from varmain.custom import *
@Anonymous(Group="Vessel", TooltipShort="Skirt", Tooltiplong="A skirt with a base", LengthUnit="mm")
@matthias_hein("MainDimension")
@Anonymous(D=LENGTH, TooltipShort="Skirt OD")
@Anonymous(L=LENGTH, TooltipLong="Length of the Skirt")
@Anonymous(D1=LENGTH, TooltipShort="Base OD")
@Anonymous(L1=LENGTH, TooltipShort="Base Thickness")
@Anonymous(OF=LENGTH, TootipShort="Skirt Thickness")
def SIMPLEVESSELSKIRT (s, D=48, L=48, D1=50, L1=.25, OF=0, **kw):
  #create the base shape of the skirt
  thck=OF
  if thck<=0:
     thck=.05*D
  s=CYLINDER(s, R=D/2, H=L, O=(D-thck)/2)
