Create Custom Pipe Support
roystercabral
Message 1 of 11
roystercabral
Hi All,
I have created a pipe support in Inventor and imported the model into Plant 3D.
Can anyone guide me or provide links to convert the model into a pipe support.
I am not looking for parametric support, i want to insert specific custom support for a certain size only and that these support should be shown on the ISO.
Thanks in advance for the help.
Roy.
Replies (10)
Message 2 of 11
h_eger
Here is an approach from the PDO team
http://www.pdoteam.com/2011/12/creating-a-custom-support-in-autocad-plant-3d/
Google search "AutoCAD Pant 3D Custom Supports"
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 11
roystercabral
Thanks Eger.
But there was a problem in the ISO , the ISO shows the piping support but doesn't dimension the support location neither does it list the support in the Bill Of Materials.
Any idea how to rectify this ?
Message 4 of 11
h_eger
Is your support in the 3d model marked with the status "Existing"?
Looks like this on the Iso.
If yes, please set the status to "New"
Should work
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 11
mauro_spadaro
Hi, for the standard Pipe SUpport you get positioning, list and dimensioning on the iso but for the custom one you get nothing even if set to New .
See image.
Any ideas?
thanks
Message 6 of 11
darrelldixon
Mauro-
Check your "Content Iso Symbol Definition" in the properties for the custom support in your model. Does it have "TYPE=SUPPORT" in addition to the SKEY? (see Hartmut's picture above -right above status)
The type definition is what determines which category an item is listed under in the BOM.
Message 7 of 11
mauro_spadaro
The TYPE and SKEY value are correctly set of course.
the result is that the "standard" support is taken into the isometric as BOM and with correct doimension whilst the custom one has neither info and dimension.
Why?
thanks
Message 8 of 11
darrelldixon
Could you possibly post a copy of your model with that straight pipe and both supports?
Message 9 of 11
mauro_spadaro
attacjed yuo get the 3d file.
thanks
bye
mauro
Message 10 of 11
Dadspackard
@mauro_spadaro,
I tested the drawing you attached and got the same results it did not dimensions your custom support.
I copied your support exploded a few time and made a new support. Same results.
What I discovered is you need to fill out the Descriptions for the support for it to dimension and show on the BOM
Let us no if this resolved your issue
Have a great day
Tom
aka, Dadspackard, Packin31
Message 11 of 11
mauro_spadaro
thanks a lot
have a nice day too
mauro
