Solved by Stormbr. Go to Solution.
Solved by scott.a.green. Go to Solution.
Dear Stormbr,
I found an article that might be able to assist you with your question. Please follow the link bellow.
Please let me know if the suggestion provided did assist you solving the issue.
Mit freundlichen Grüßen,
Kind Regards,
Roann Knight
www.autodesk.com
Dear Stormbr,
I apologize I miss understood. Did you manage to solve the problem? I just wanted to follow up witn you.
Kind Regards,
Roann Knight
www.autodesk.com
I think this is closer to what you are looking for:
How to migrate an AutoCAD Plant 3D project from SQLite to SQL Server or SQL Express
..."Running the PnPProjectMaintenance.exe file will convert a project from the default database (SQLite) to SQL Express or SQL Server. You can also copy or move a SQL Server database to a different database name or server."
Hope that is more in line with what you are looking for. You should be able to copy the database over using this method.
Have you seen this?
How to rename a project in AutoCAD Plant 3D respectively AutoCAD P&ID
This should allow you to copy the project under a different name - you would need to change these .dcf files:
It could also be a limitation of SQLite. I typically use SQL Server or Vault.
One last thing, creating a NEW project off of the old one and moving over the drawing to the P3D project folder would create a new database and would probably result in less issues along the road rather than copying over the database directly.
