AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Convert From Inch To mm (DN)
5 REPLIES 5
Ahmed1081975
2615 Views, 5 Replies
Hi Autodesk Support,
What is the Steps to Convert Catalog ASME to Excel (Inch) and Return Back by Millimeters Catalog Using Catalog Builder??
2" To DN50  For Example
Ahmed Helal
5 REPLIES 5
Dan.Scales
in reply to: Ahmed1081975
Hi Ahmed,
You should be able to do this by exporting to Excel and changing the sizes from imperial to metric.
Once you have done that you can use the Catalog Builder to build the metric version.
One point though is that you need to edit the Excel sheet "Port Unit_S-ALL" from Mm to mm before you build the catalog again.
Dan
Dan Scales
Ahmed1081975
in reply to: Dan.Scales
Thanks Dan,
Can you please give me screen shot or vidieo For the steps to do that,
Ahmed Helal
Dan.Scales
Hi Ahmed,
I have done a quick test and it looks as though it is not be possible to convert the spec.
It is however possible to switch the editing units to metric though:
Dan
Dan Scales
Ahmed1081975
Hi Dan,
I ask to convert the Catalog Not Specs??
please Answer
Ahmed Helal
Dan.Scales
Hi Ahmed,
The screen shot shows the catalog being edited in metric rather than imperial.
The word "spec" in my previous post was a typo. I should have typed catalog.
Dan
Dan Scales
