Confused about Autocad with Plant 3d toolset and Autocad Plant 3D
rafimh2022
Message 1 of 11
rafimh2022
Hi All,
What is the difference between Autocad with Plant 3d toolset and Autocad Plant 3d? Is Autocad stop releasing Plant 3d and it added with Autocad?
Rafi.
Replies (10)
Message 2 of 11
Michiel.Valcke
The toolset is a type name given for the separate software which is AutoCAD Plant 3D.
Both AutoCAD and AutoCAD Plant 3D are separate softwares, each with their own updates and functionalities. But the latter is called a toolset, because it is build upon the AutoCAD software, and it contains all the functionalities of a basic AutoCAD.
It is just a way to talk about this series of AutoCAD based software packages. Before being called toolsets they were often colloquially called 'verticals'. AutoCAD Plant 3D is not the only toolset, there are others (such as MAP 3D / Architectural / MEP / ...)
Message 3 of 11
rafimh2022
Dear Mr. Michiel.Valcke, Thanks for your quick response on this subject I am confused because of following info from Autodesk website.
thanks,
Rafi.
Message 4 of 11
Michiel.Valcke
That is because the licensing model has changed. Since a few years you no longer buy licences for the toolsets seperately, instead you get a license for AutoCAD which will automatically include licenses for all toolsets including raster design. So if you have plant 3D it means with the same licence you can download, install and use map 3D, raster design, MEP, ...
Message 5 of 11
DarrenP
Plant 3D you cannot buy separately anymore
If you need Plant 3D you have to Autocad with specialized toolsets which includes Plant 3d & other toolsets
DarrenP
Message 6 of 11
domy_bia93
how can i open plant3d?
Message 7 of 11
matt.worland
You will have to install the ToolSet from your Autodesk account. Then is should add a Plant 3D desktop shortcut you can click on. Beyond those steps, we need to know what you have tried.
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
Message 8 of 11
domy_bia93
I tought it was inside Autocad, now i downloaded another exe file specifically for plant3d and installed it, thanks very much. Can you point to me some  useful tutorial in order to draw flux and p&id diagrams? also something to learn how to proper export the diagram in a clear png. (I tried the export to pdf, but the lines are huge and overall not a good export)
Message 9 of 11
matt.worland
I haven't tried any online tutorials so Im not sure of any to recommend beyond trying what you find through an internet search.
Here is a starting point from Autodesk:
https://help.autodesk.com/view/PLNT3D/2022/ENU/?guid=GUID-B893C006-637E-44EB-8C19-737AB2847AE7
As far as PNGs go, its not a typical deliverable type from AutoCAD, but here are some links that should help:
https://forums.autodesk.com/t5/autocad-forum/high-resolution-plotting-dwg-to-png/td-p/6840345
https://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-5337AD1B-08B1-495A-B1D0-B2A59AF1AA49
Message 10 of 11
domy_bia93
Thank you very much. What about exporting to a pdf with the page dimension as an A3 sheet? sorry but i am struggling a little bit finding tutorials.
Message 11 of 11
matt.worland
The Autodesk help files are very helpful. Search on this link:
https://help.autodesk.com/view/ACD/2022/ENU/
You should find something like this:https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-EC9C6D47-814E-476D-840F-04104CF72B78
Play with the Plot command using the DWG To PDF.pc3 plotter and choose your sizes.
From there just try the buttons and settings to see how the react until you get what you are after.
