AutoCAD Plant 3D Forum
Welcome to Autodeskā€™s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Configuration of Iso cotation
2 REPLIES 2
david.gerard.be
399 Views, 2 Replies
i want create a style for my iso .
the trouble is , i don't arrive to have a good configuration.
i want cotation in the axis of all valve , with flange valve or not flange valve.
and the same for tappings. Its always one or other and not all in  same time .
the configuration is on this panel but why config ?
thank for answer
2 REPLIES 2
Hi
Which plant 3d version?
In Plant3d 2018 version, go to project Set up > Isometric DWG settings > Dimensions.Capture.PNG
Select "Center" at all valve types.
EDIT: i see in your printscreen that you are editing the dimensioninig for drain/vent theme. Check all the themes you are using
Regards
ok for axis of valve.
it s version 2018.
the trouble is  he take the center of valve and not  the connection flange/flange .
i want no double cotation and i don' t want the lenght of the items .just the axis of all items
sorry for my english .
tank you
Technology Administrators
AutoCAD Beta
