i want create a style for my iso .
the trouble is , i don't arrive to have a good configuration.
i want cotation in the axis of all valve , with flange valve or not flange valve.
and the same for tappings. Its always one or other and not all in same time .
i joint screen for my example.
the configuration is on this panel but why config ?
thank for answer
Solved by JUANCARLOSBLASCO4129. Go to Solution.
Hi
Which plant 3d version?
In Plant3d 2018 version, go to project Set up > Isometric DWG settings > Dimensions.
Select "Center" at all valve types.
EDIT: i see in your printscreen that you are editing the dimensioninig for drain/vent theme. Check all the themes you are using
Regards
ok for axis of valve.
it s version 2018.
the trouble is he take the center of valve and not the connection flange/flange .
i want no double cotation and i don' t want the lenght of the items .just the axis of all items
sorry for my english .
tank you
