I am working in a waste water treatment plant project on Plant3d ver. 2020 and facing an issue with identifying a concrete channel in P&ID and how to combine it with a 3D model done on Revit and merged into Plan3D platform ...
First: In P&ID the symbol for this channel supposed to be a single line ,which is identified in P&ID as a pipe and that isn't right
Second: I am facing an error as this channel supposed to be connected to Page connector ,which required an ID to be connected to the next drawing ,on the same way this channel suppose to have a code and that's another issue as I can't give it a code in 3D platform because it's not a Plant3d element ...
So my question is : How I make the software differ between Pipe line and concrete channel in P&ID and how to give it a coding in the same time with respect to be connected to a solid came from Revit and facing the same issue in iddintefaing it as nothing in Plant3d library understand it when I convert it to a smart object ..
Thanks in advance
