AutoCAD Plant 3D Forum
Change Skew Angle for an Individual / Single Isometric Drawing
3 REPLIES 3
petestrycharske
1631 Views, 3 Replies
petestrycharske
All,
Good morning!  I have some piping that is drawn in an orthorgraphic fashion (parallel to the X, Y, Z axis) and then some piping joining those together that are not modeled in orthographic angles (say 45 degrees instead of perpendicular to both).  The orthographically drawn pipe comes in just fine with my production isometric drawings, but the angled pipe displays with a different skew angle.  Is there a way to adjust the skew angle of just one isometric sheet or is there some setting that can help me out?  I just want to make sure that my isometric drawings are consistent.  If you have any questions, please do not hesitate to contact me.  Thanks in advance for any assistance, hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
All,
Peace,
Pete
3 REPLIES 3
AHepker_HOB
Hi Pete,
The guys over at PDO Team seem to have a post discussing just about everything (except for what I look for Smiley Happy). I have not had a chance to test the method detailed in the link below for isos, but the concept seems correct. The PCF files that are written determine how everything is drawn, and I would guess that adjusting your UCS to specific skewed piping configurations might get you there. Hope that helps.
http://www.pdoteam.com/2013/08/creating-an-isometric-view-of-a-skewed-model/
Cheers,
Andrew
Check out our blog @ HouseOfBIM.com
Hi Pete,
Cheers,
Andrew
TomislavGolubovic
Why?
If the pipeline is skewed to whichever North you happen to be using for the Plant then its skewed, if its in the N-S-E-W direction then its not.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Why?
Tomislav Golubovic
Autodesk, Inc.
AHepker_HOB
I agree. Drawings produced not in a standard true north orientation will not align with the building, however, from a fabrication standpoint, aligning the UCS to the skewed piping should allow for a more easily readable drawing. As long as all dimensions are accurate, then the Fabrication should come out correct and with a lower likelihood of error. It's certainly not a practice that I would necessarily condone, but I have seen some rather complex piping systems that could have benefitted from using just such a practice.
