catalog editor sizes have disappeared
veronica.rosaGJXV3
veronica.rosaGJXV3
When I try to create a new parametric item from a catalog, I can't because the default size lists appear as "Undefined Size" and I can't create any items. In addition, the various sizes of the elements that already had created in the past, appear "mm". The same happens in Autocad Plant 3D, the sizes of the size list of the "Part insertion" menu appear with "mm".
Thank you.
Greetings.
Gokhan_Kaya
Hi
firstly you must select unit and  is it not selectable ? when you click size combobox
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudo") ile ödüllendirin.
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
veronica.rosaGJXV3
I select metric units and the list of diameters does not appear. In Imprerial units either.
Vasu27
Hi @veronica.rosaGJXV3 ,
I suspect the file 'NominalDiameterMap.csv' in location 'C:\Program Files\Autodesk\AutoCAD 2019' might be corrupted. If you have a backup copy of that file, can you try replacing that and see, if that helps?
Vasu
veronica.rosaGJXV3
Hi, thanks for your reply.
I did this but it didn't work either. I finally solved it by reinstalling the program.
Regards.
