Can't Disable Gasket Dimensions
_Jeff_Roy_
Message 1 of 15
_Jeff_Roy_
I've been scouring the forums and applied all the suggestions I've found for disabling gaskets being individually dimensioned on isometrics. I've got the Gasket Dimensioning dropdown set to Include in Component  for every theme, I've gone through the XML and changed the AnchorPoint (Flange)  filter from 'Flangelike' to 'Flange' for every theme, etc. At this point it seems like I've exhausted my options, at least as far as the fixes that have been recommended when this question has been asked in the past.
Does anyone know of something I might not have tried yet that could resolve this? We just want the gasket widths to be included in the overall dimension (as opposed to dedicated gasket dimensions) with a gasket indicator shown. It seems like this should be an easy setting to apply but apparently not. The obvious setting that should be controlling this, isn't.
Thanks!
Replies (14)
Message 2 of 15
DVaquand
Hello
Is this principle what you want to achieve?
An overall rating, including joints, with a G indicator, for example, to indicate that there is a joint.
== French ==
Est-ce que c'est ce principe que vous souhaitez réaliser ?
Une cote globale, incluant les joints, avec un indicateur G, par exemple, pour indiquer qu'il y a un joint.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 3 of 15
_Jeff_Roy_
@DVaquand That is exactly what we want minus the 'G' - we do not want that character to appear, only the small line/dash indicating that the gasket width is included in the dimension.
Message 4 of 15
DVaquand
Hello
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 5 of 15
_Jeff_Roy_
@DVaquand Yes, I've already verified this has been applied to every iso theme under my isometric style, as well as several other suggested fixes but the iso generation process is not "respecting" this setting.
Message 6 of 15
DVaquand
Hello
Open the "IsoConfig.xml" file and check that for each theme, for each "Dimensions", the dimensional setting of the joint exists.
If this setting does not exist in a theme, create it. You can copy/paste a setting
== French ==
Ouvrez le fichier "IsoConfig.xml" et vérifiez que pour chaque thème, pour chaque "Dimensions", le paramétrage dimensionnel du joint existe bien.
Dans le cas où se paramétrage n'existe pas dans un thème, le créer. Vous pouvez faire la copier/coller d'un paramétrage
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 7 of 15
_Jeff_Roy_
@DVaquand Thanks for the suggestion. I copy/pasted the gasket theme to all categories of anchor points where it didn't already exist and ensured the settings matched your screenshot ('Global' checked, 'Enabled' unchecked). I tested and the isometrics still generate dimensions at every gasket. Just to test the isometric settings, I changed the gasket dropdown to 'Do not dimension' and there was no change to how gaskets were processed, it still generated a dimension at each one. It seems the gasket dimensioning settings are somehow disconnected from how the iso generator actually operates. None of the settings I change have any impact on how gaskets are managed.
Message 8 of 15
DVaquand
Hello
Which Plant 3D version are you working on?
Do you have the opportunity to do a test on another style of ISO output, for example "Check A3" having taken care, in the project settings, to include the joints in the dimension of the component.
Can you also load the project in another version of Plant 3D to see?
== French ==
Sur quelle version Plant 3D travaillez-vous ?
Avez vous l'opportunité de faire un test sur un autre style de sortie iso, par exemple "Check A3" en ayant pris soin, dans le paramétrage du projet, d'inclure les joints dans la dimension du composant.
Avez vous également la possibilité de charger le projet dans une autre version de Plant 3D pour voir ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 9 of 15
_Jeff_Roy_
@DVaquand I'm on Plant 3D 2022. Check A3 manages the gasket dimensions the way we want. For example, valve dimensions are shown from outside mating flange to outside mating flange, no gasket dimension, gasket symbols shown inside the dimension to indicate the gasket width is included.
Message 10 of 15
DVaquand
Hello
I conclude that the iso output style has a problem.
Finding the error may take a long time.
Maybe recreate a new style starting from one that works and add your own parameters step by step...
== French ==
J'en déduis que le style de sortie iso a un problème.
Trouver l'erreur risque d'être long.
Peut-être recréer un nouveau style en partant d'un d'un style qui fontionne et lui ajouter pas à pas vos propres paramètres ...
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 11 of 15
km4504
Was this project created in 2022?
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
Message 12 of 15
_Jeff_Roy_
@km4504 Yes, this is a 2022 project
Message 13 of 15
Michiel.Valcke
Can you share the iso folder (for the xml, template, atr. etc) so we can test on our end?
Message 14 of 15
_Jeff_Roy_
@Michiel.Valcke Iso folder for the theme being used is attached. Thanks for taking a look into this. Gasket dimensioning seems to be inconsistent, some have a 1/8" dimension generated, others not.
Message 15 of 15
Michiel.Valcke
I'll need to make an imperial project to thoroughly test this, (and add all the additional pipe line group properties that you are referencing in the iso.atr 🙂 )
But when looking at your isoconfig.xml I saw that your fitting to Fitting Gasket dimension option was still checked for the string dimensiontype, for all your different themes. I unchecked them all and saved the config. Try the result in attachment.
