Using the samples provided in the Plant 3D (P3D) SDK I have been able to convert a collection of blocks into a P3D Miscellaneous equipment entity.
The properties are being set and everything works until I add nozzles to the equipment. The "Disconnected ports" are added but when I click on the pencil icon to edit the nozzle nothing happens.
What is worse is that after adding the nozzles the Modify Equipment no longer works. Before adding nozzles I can click on the equipment to open the dialog to see the properties. After adding nozzles the command line says. "Invalid selection. Only one equipment item can be selected." when I click on anything associated with the equipment entity.
I use:
eqHelper.SetNozzleLocation(s_CurrentEquipmentType, ni,
new Point3d(nozzle.OriginX, nozzle.OriginY, nozzle.OriginZ),
new Point3d(nozzle.EndX, nozzle.EndY, nozzle.EndZ),
0.0, ecs);
to add the nozzles.
Any suggestions will be appreciated.
Thanks.
Solved by bill_cochell95RWZ. Go to Solution.
It turns out, the problem happens when I use a value for the third parameter when I call the Update Equipment Entity method of the Equipment Helper.
This works for me:
equipmentHelper.UpdateEquipmentEntity(s_CurrentEquipmentId, s_CurrentEquipmentType, null, s_CurrentDwgScale);
