AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
BOM reports - would like to create a BOM report for certain lines in a project
11 REPLIES 11
Message 1 of 12
2610 Views, 11 Replies
I am verturing into some more uncharted territory for myself.
I have created a project with several existing pipe lines along with about 7 new lines.
I have recently stumbled onto the reports section of AutoPlant 3D and thought I could easily create a report of BOM of just new pipe.
I also thought if I could export all the data to a excel spreadsheet then sort it some how to only show the material I am interested in.
I am not having much luck.
I am using AutoPlant 3D 2016 and AutoPlant 3D report creator 2016.
Steve
Tags (3)
11 REPLIES 11
Message 2 of 12
h_eger
attached the screenshot for configuring the PlantReporter 2016.
http://autode.sk/1UbKcYk
This filter expression all EXISTING PipeLines are not on the BOM.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 12
in reply to: h_eger
it says Private Video...contact author for permission to view
Message 4 of 12
h_eger
sorry my mistake
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 12
in reply to: h_eger
Thank you, in the middle of getting some stuff out that was due last thursday, but will give you post a try in a little while, seems to be what I am looking for.
Message 6 of 12
in reply to: h_eger
h.eger, video worked great...that gives me a complete BOM of all new pipe, can I break it down by line number?
Steve
Message 7 of 12
h_eger
to test the MTO
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 12
in reply to: h_eger
i opened the zip file and tried running the steve.rcf file, Windows can't open this file?
Message 9 of 12
h_eger
copy the file "Steve.rcf" to "C:\ProgramData\Autodesk\Autodesk AutoCAD Plant 3D 2016\R20.1\enu\ReportCreator\ReportFiles"
Open the ReportCreator
1. select your Project
2. click on Settings
3. Location for ReportCreator Templates
4. click on ReportConfiguration
5. select Steve
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 12
in reply to: h_eger
Thank you again h.eger, worked great.
Steve
Message 11 of 12
in reply to: h_eger
A while back you fixed me up with a report for me to do a MTO for my project...I have played around with it a little and can't get it to put the quantity in.
I am trying to get these
Line #1
Size - Spec - Quantity - Short Description
Line #2
etc...
I haven't figured out how to add a table cell or copy a table cell?
Steve
Message 12 of 12
wstowe
in reply to: h_eger
Hello @h_eger
I tried your report but my problem is how to change it to use imperial dimensions. It currently shows length of pipe in meters but I need it in feet and inches.
Thank you.
