Blocks / Step Files
Blocks / Step Files
matthew.m.peterson
Blocks / Step Files
matthew.m.peterson
I am very new to Plant 3D so please bare with me. I am creating a 3D model for my fueling system layout and there are some control valve step files I would like to use. I inserted the step file (valve) into my 3D drawing, converted the valve to equipment and then added nozzles (RF Flanges) to each end of the valve. Although I added class 150 raised face flanges to each end of the control valve, I cannot get it to connect to the raised face weld neck flange from the standard tool palette without a leak showing. Is there something that I am missing?
h_eger
Dear @matthew.m.peterson ,
with a very high probability you have overlooked something. Can you please upload the properties "Port Properties" an image
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
AndyDavisArkance
HI,
A couple of things to think about here.
  1. To make a flanged connection using the default settings: the Nominal Diameter, Pressure Class and Facing values of the mating flange faces must match exactly.
  2. If you're importing CAD models of valves, these would be better managed as piping fittings rather than equipment items. You would then be able to add them to a catalog/pipe spec(s) and have them available on your toolpalette.
Andy
Andy Davis
Industry Specialist
ARKANCE
matthew.m.peterson
I am not even seeing port properties, so I must be doing something wrong..
matthew.m.peterson
Andy,
What are the steps to add them using this method?
AndyDavisArkance
This should help:
How to create a custom part in AutoCAD Plant 3D using an AutoCAD block
Andy
Andy Davis
Industry Specialist
ARKANCE
