I'm using DIN EN spec (https://apps.autodesk.com/PLNT3D/en/Detail/Index?id=6522835772429418025&appLang=en&os=Win64) for piping on my projects and after i create a report (3D Parts - Material List) for it i can't see my elbows on that report. Pipes, Valves, and support objects are in it but only elbows aren't there. Is there a solution to my problem?
Solved by h_eger. Go to Solution.
Have found the solution. If anyone has the same problem will be useful...
In the drawing pipeline was '' Pulled Pipe'' because of that my elbows were not showing on BILL OF MATERIALS
for solution: go on drawing see which pipeline is combined. Click the right mouse to that combined pipe and you will see there '' Convert to Pipes and Bends'', then you will be able to see your elbows on your bill of material list.
Dear @canan.kartal ,
I have tested with DIN EN Pipe Spec.
Everything is in order pipe bends are in the material list "3D Parts".
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
