AUTOCAD PLANT 3D FLANGE CONNECTION
ettiene.willemse
ettiene.willemse
Good day
I am having trouble with connection  a pipe to a valve. It pops up this error and i am not sure how to fix the problem.
Any suggestions?
h_eger
Dear @ettiene.willemse ,
there is no flange with Pressure Class 150 in the PipeSpec CS1500 you are using.
Can it be that you have a confusion of the Pipe Spec CS150 and CS1500?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
ettiene.willemse
With the project we are busy with we had to make a CS1500 class because of the entire plant running on 150 bar.
h_eger
OK then in your Pipe Spec CS1500 is a wrong component with flange connection #150
Hartmut Eger
Senior Engineer
XING | LinkedIn
ettiene.willemse
What should I add?
Because I don't understand the error
schusterAPRO
Hi @ettiene.willemse
please check the connection ports of your valve...size, facing and pressure class and compare that to your flange from your spec CS1500. They must match to be connected.
tech_kong_vip_s10
The following three conditions must be met,not a single one can be omitted
1.Nominal diameter
2.Pressure rating
3.Sealing surface
I hope you can succeed
