AutoCAD Plant 3D 2018 Spool Auto Numbering
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have developed a theme that will auto number spool ISO's that are synced to a spool map. This method also allows only spool fabrication entities to show up on Spools ISO's whereas default spool methodology also applies field erection entities. We were having issues with number continuity between Map & Spool until ADSK informed us that the start point XML was not properly over writing between generation of Map & Spool. By physically deleting the start point XML between generations the numbering continuity is consistent. Please note that we only activated portions of the XML coding that already resided within the isoconfig.xml. We would like to share this theme with the Plant 3D community if this has not already been derived by you or your company.
