AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
assign tag line number
4 REPLIES 4
josegs
784 Views, 4 Replies
Hi there,
I need to change the way it generates P3D 2016 line number.
P3D default :
( Example) 100.100.10-80-10HA10F01B1
And I need : 100.100.10-80/10HA10F01B1 How I can replace " - " with " / "? Thank you!!
4 REPLIES 4
h_eger
in reply to: josegs
see Picture
Regards
Hartmut
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
josegs
in reply to: h_eger
Thank you for responding , but it's not exactly what I need .
I need the symbol "/" is between the DN and spec :
xxx.xxx.xxx -DN / spec
If I do what you tell me the result is shown in the accompanying drawings .
Best regards, JoseTAG FORMAT.PNGCREATE NEW LINE NUMBRE.PNGTAG FORMAT.PNGCREATE NEW LINE NUMBRE.PNG
h_eger
in reply to: josegs
Modification in ISOCONFIG.XML
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}/{1}" LineFormat="{0}" />
Regards
Hartmut
Hartmut Eger
Senior Engineer
XING | LinkedIn
josegs
in reply to: h_eger
Perfect!!!
It is exactly what I needed .
Best regards, Jose
