Hi there,
I need to change the way it generates P3D 2016 line number.
P3D default :
( Example) 100.100.10-80-10HA10F01B1
And I need :
100.100.10-80/10HA10F01B1
How I can replace " - " with " / "?
Thank you!!
Solved by josegs. Go to Solution.
see Picture
Regards
Hartmut
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thank you for responding , but it's not exactly what I need .
I need the symbol "/" is between the DN and spec :
xxx.xxx.xxx -DN / spec
If I do what you tell me the result is shown in the accompanying drawings .
Best regards, Jose
Modification in ISOCONFIG.XML
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}/{1}" LineFormat="{0}" />
Regards
Hartmut
Hartmut Eger
Senior Engineer
XING | LinkedIn
