adding spec to plant 3D changes the properties seen in navisworks nwc file
mbeason8A7G8
mbeason8A7G8
I am adding a spec to plant 3D and for some reason adding the spec changes the output of the properties I see in the NWC file. Without the spec I can see all properties from Plant 3D to nwc. I add the spec and presto, very limited properties in Navisworks. Remove the spec and everything works again. the machine that created the spec can do all functions properly.  What gives?
Plant 3D version: P3D_S051.02 Autodesk AutoCAD Plant 3D 2022 (S.162.0.0 AutoCAD 2022.1.2)
Navis exporter: Autodesk Navisworks Exporters 2022 (version: 19.2.1383.37)
Spec created on:  P3D_S051.1003 Autodesk AutoCAD Plant 3D 2022.1 (S.162.0.0 AutoCAD 2022.1.2)
Navis Exporter: Autodesk Navisworks Exporters 2021 Exporters - 64 bit (version: 18.0.1347.51)
Tomislav.Golubovic
What do you mean by "Remove the spec"?
mbeason8A7G8
I am working on a local project. No server or collaboration based. I right click on "Pipe Spec" in the Project Browser to copy spec to project. No problem. I can add the spec and draw pipe. Then when I run an NWCOUT I see very limited set of properties. Then when I right click to remove spec from project, the properties on NWCOUT behave as expected.
