Hello, I would like to know how to add a symbol to a control valve if possible.
Solved by h_eger. Go to Solution.
yes under Non Engineering Item --> Actuator
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thank you for your help. Here another question, when you place regular valve it places the pipe size in the description, which we like, is there a way for this to done when placing a control valve? I place it a no size is placed.
yes, you can view the Hand valve Annotationsystem and reconfigure it for the control valves.
Hartmut Eger
Senior Engineer
XING | LinkedIn
