AutoCAD Plant 3D Forum
Addind a symbol to a control valve
3 REPLIES 3
OPerezBC2SQ
187 Views, 3 Replies
Hello, I would like to know how to add a symbol to a control valve if possible.
3 REPLIES 3
h_eger
in reply to: OPerezBC2SQ
@OPerezBC2SQ ,
yes under Non Engineering Item --> Actuator
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
OPerezBC2SQ
Thank you for your help. Here another question, when you place regular valve it places the pipe size in the description, which we like, is there a way for this to done when placing a control valve? I place it a no size is placed.
h_eger
@OPerezBC2SQ ,
yes, you can view the Hand valve Annotationsystem and reconfigure it for the control valves.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Technology Administrators
AutoCAD Beta
