Actuator Block wrong location for multiport valve in 3D model
Matias.Martin79
Matias.Martin79
I have the following problem, I am using the Tuchenhagen multiport valve catalog but I need to change the actuators to make them look more realistic. I have generated the actuator block and I have generated the PLANTPARTCONVERT.
I assigned the actuator to the valve and everything works perfect
The problem is that when I modify the angle in the lower housing, the insertion point is modified in the Y axis
Otherwise, the insertion point moves on the X axis
does anybody know how I can fix it?
I would need that in all cases the insertion point be the same
Thank you
WWBierma
Did you found the solution or a work around for this problem?
I have the same problem in Plant 3D 2020 and it is very annoying.
Matias.Martin79
no
WWBierma
That sucks...
orA3ZRE
I have same problem, but if you write 0.000001 it is ok
rajendra.prajapat
@Matias.Martin79  please put the angle as per below:
Angle  = current angle value  + 0.0000000001
for exmalpe 90
Angle= 90+0.0000000001=90.0000000001
then actuator will not move.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
joakim_lindh
The actuator for multiportvalve need to lay down flat and point in +Y when you create the block for it.
Following this guide may help you. We hade the same issue until we found out how multiport valves are treated by the system.
Isometrics- 3 Way Safety Selector Valve (Multiport Valve) - Autodesk Community
