AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
A lot of ISOs are generated for a short section
6 REPLIES 6
jalal.pakdaman
394 Views, 6 Replies
Dears
I am in a serious trouble while generating ISO drafts from my model. I applied all set-up modifications from below:
https://knowledge.autodesk.com/support/autocad-plant-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
However, still a short section will be scattered to plenty of ISO drafts. For instance every TEE comes to one sheet!
The above model comes to 4 sheets!!. Please help me.
6 REPLIES 6
h_eger
in reply to: jalal.pakdaman
dear @jalal.pakdaman ,
this can have different reasons:
- Unconnected parts
- Incorrect line number assignment
- Incorrect sheet splitting setting
can you please upload the model and your PCF file for us to test
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jalal.pakdaman
in reply to: h_eger
The PCF and ISOs were attached.
I need the whole 3d model becomes 3 sheets not more.
Another question. The ISOs which I extract from my model does not apply scale on pipe sizes, as a result every long pipe takes a whole page. So I had to draw long pipes in my model shorter than their real size in order to have more pipes and components in a single page. Is there any solution for this to have maximum pipes in a single page with their real length size?
Many Thanks
h_eger
Dear @jalal.pakdaman ,
for me the iso looks correct.
Iso template Final_A2 with Plant 3D 2022.
The iso is divided into 2 parts because the PCF consists of 2 pipeline numbers.
Hartmut Eger
Senior Engineer
XING | LinkedIn
jalal.pakdaman
in reply to: h_eger
Dear @h_eger
could you please see the attached file. I am trying to get the ISO in 1 sheet but it is coming under 4 sheets! Is there any solution for that?
h_eger
Please check the pipeline for 3 points:
1 +2 are connection errors of Flange and Valve!
3 has no connection to the main pipeline
27-02-_2022_11-08-51.jpg27-02-_2022_11-11-01.jpg27-02-_2022_11-12-11.jpg27-02-_2022_11-12-58.jpg
Hartmut Eger
Senior Engineer
XING | LinkedIn
jalal.pakdaman
in reply to: h_eger
YOU ARE FANTASTIC BODY.
MANY THANKS.
