Dears
I am in a serious trouble while generating ISO drafts from my model. I applied all set-up modifications from below:
However, still a short section will be scattered to plenty of ISO drafts. For instance every TEE comes to one sheet!
The above model comes to 4 sheets!!. Please help me.
Solved by h_eger. Go to Solution.
dear @jalal.pakdaman ,
this can have different reasons:
- Unconnected parts
- Incorrect line number assignment
- Incorrect sheet splitting setting
can you please upload the model and your PCF file for us to test
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
The PCF and ISOs were attached.
I need the whole 3d model becomes 3 sheets not more.
Another question. The ISOs which I extract from my model does not apply scale on pipe sizes, as a result every long pipe takes a whole page. So I had to draw long pipes in my model shorter than their real size in order to have more pipes and components in a single page. Is there any solution for this to have maximum pipes in a single page with their real length size?
Many Thanks
Dear @jalal.pakdaman ,
for me the iso looks correct.
Iso template Final_A2 with Plant 3D 2022.
The iso is divided into 2 parts because the PCF consists of 2 pipeline numbers.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Please check the pipeline for 3 points:
1 +2 are connection errors of Flange and Valve!
3 has no connection to the main pipeline
Hartmut Eger
Senior Engineer
XING | LinkedIn
