AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
6 port bleed ring
6 REPLIES 6
gcostanzo
1291 Views, 6 Replies
6 port bleed ring
We have a 4" bleed ring,  with Four (4) 3/4" drill holes.   A total of 6 ports.   I have tried to make this part in the catalog but it has a limitation of 4 ports.
So I tried custom parts from the Ribbon bar.  Again the 4 port limitation.   I tried to create if from a custom block and when I use convert parts,  I ran into the 4 port limitation again.
Is there a way I can make this bleed ring.
Thanks for any help.
6 REPLIES 6
h_eger
in reply to: gcostanzo
Hi @gcostanzo,
do you have a sample sheet of this Bleedring?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
gcostanzo
in reply to: h_eger
No cut sheet it simply states in their  specs  "ASME 150 rf/ff bleed ring, four drilled bleed holes and 3/4" FNPT thd taps, CS hex head plugs, Cs body."
  I was planing on building the part with a (2)  bleed holes  at 15 degs from the 0 and 90 position,  or one at every qua.  depending on feed back from the engineer.
ryan.bales
You can put as many ports as you want on a block based part just type the number, the drop down only goes to 4. I put 8 on my sample bleed ring - see below.
Ryan Bales
Fusion 360 Product Support
ryan.bales
Were you able to test out what I showed?
Ryan Bales
julie_havard
in reply to: ryan.bales
When we take the one with only 3 ports, can we modify it to 4 ports? We tried to replace the -2 parameters but it stay at 3 ports.
h_eger
@julie_havard ,
Parametric graphics or block-based?
Hartmut Eger
Senior Engineer
XING | LinkedIn
