How do you adjust the pipe bend radius in Plant 2018?
The bends seam to become one entity with the pipe and the radius property is no longer available.
Solved by dave.wolfe. Go to Solution.
Hey Rod.
It's a project setting now, and the default is treating bends as part of the pipe.
Is there some way to accommodate different bend radii in the same project? We have a project using pulled bends, and there is a mixture of 3D and 5D bends on the same line size for different parts of the same project.
