Is there a way to generate an ellipse in AutoCAD Web?
laneteach
laneteach
I am teaching a remote High School AutoCAD class and the only common program the students can run from home due to computer (or lack of) equipment is AutoCAD Web. One shape we need is an ellipse. The command is not there and I have not found a way to generate it (stretch, polyline, etc.). Any suggestions?
cheryl.buck
Autodesk Support
Autodesk Support
Hi @laneteach,
I see that you are visiting as a new member to the AutoCAD Web App forum. Welcome to the Autodesk Community!
While there are a number of basic shapes available in the AutoCAD Web App, the ellipse is not currently included. I think this would be a great addition and encourage you to submit the idea to the Product Feedback team. You can do this from the Help (?) in the upper right corner in the application window:
For more information on the Web App, see the following link:
Hitchhiker's Guide to the AutoCAD Web App
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Thomas_Stuehle
Hello @laneteach
Did the post by @cheryl.buck  helped you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
I was just testing additional steps which might be a solution for you and the students
1. Create a drawing with an ellipse in AutoCAD Desktop or take the drawing I attached to this post.
2. Send the drawing to the students.
3. Upload the drawing to the file manager or your external storage provider.
4. You could use the drawing as a starting point and change the ellipse in this drawing. The properties already recognize it as an Ellipse. Just move and edit it as you want with the grips.
5. Until now creating a block from it and inserting this block in other drawings did not work on my side but when you are able to manage it, this could be a comfortable solution to add an ellipse also to other drawings.
Did the post helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
laneteach
Thank you!
 I will give that a try as soon as I get a moment...
Gerry
