How to count the items with AutoCAD web?
tiffanycheng0107
tiffanycheng0107
Community Visitor
Community Visitor
ASA title shows, wanna know how to count the items in AutoCAD web, see many tutorials in YouTube which is in AutoCAD version. For AutoCAD web there isn’t any videos, please help, thank you.
pendean
Community Legend
Community Legend
AutoCADWEB does not have a COUNT command option. Or much of any core commands from desktop AutoCAD to automate counting either. Sorry.
I've not tested it, but you might be able to run a LISP that does counting, lots out there on the web if you wish to search for them.
handjonathan
Hi @tiffanycheng0107
Thanks a lot for posting your question to the forums!   Has the solution suggested by @pendean helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
zafariqbal07f
I had a similar question when I first started using AutoCAD web. Counting items isn't as straightforward as in the full AutoCAD version, but you can still manage it. You can try selecting the items manually to see the count in the properties or use a simple workaround by copying the items to a desktop version if that's an option. It’s not as seamless as in AutoCAD, but it gets the job done!
vladimir_michl
E.g. the SelectSimilar tool for AutoCAD web app will display the number of selected (similar) objects. See:
https://www.cadforum.cz/en/selectsimilar-extended-selections-for-autocad-incl-lt-and-web-tip13878
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
contentc697
Community Visitor
Community Visitor
To count items in AutoCAD Web, you can follow these steps:
  1. Open Your Drawing: Load your drawing in AutoCAD Web.
  2. Select Objects: Use the selection tool to select the items you want to count. You can click and drag or hold down the Shift key to select multiple objects
