Cannot insert image
Cannot insert image
Cannot insert image
When using the AutoCAD Web App, I cannot insert my image. It is a png. I can attach it as a XREF, however it doesn't appear on the screen. When typing in the INSERT command, it brings me to blocks. However, I cannot insert my file as a block. I need this image and to be able to overlay more.
mwn
Currently AutoCAD web does not support the IMAGE or IMAGEATTACH commands. If an existing DWG has an image already attached it will resolve and display in the DWG. Only 4 image types are currently supported: BMP, PNG, GIF, JPG.
Best regards,
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Thomas_Stuehle
Hello @Anonymous
Could the information provided by @mwn  help you and answer your question?
Currently using XREF is the way forward.
I just tested with two of the image formats mentioned by @mwn (BMP, PNG, GIF, JPG) and they worked for me. I suggest that they are inserted with a small height/width - I experienced the same on my side. When I checked I noticed that they are inserted with a unit value of 1 for width:
Please try the steps again and zoom in at the location where you selected the insertion point of your image. I suggest that you will find them.
Please select the whole image with a window selection and you will be able to adjust the size afterwards to the size you want.
Did the post helped you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Thomas_Stuehle
Hello @Anonymous
Did the post above helped you and answered your question? 🙂
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward. 🙂
Best regards,
Thomas
Thomas Stühle
umarsyaifullah
Community Visitor
Community Visitor
how bout my case, my jpg file able to upload buat cant attached into drawing page, please advise
vladimir_michl
JPG files should be attachable. There are two options how to insert/attach raster images in AutoCAD Web - see:
https://www.cadforum.cz/en/two-options-for-inserting-images-into-dwg-in-autocad-web-app-tip14532
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
jeansoares1803
Community Visitor
Community Visitor
Spoiler
