Text size in dimension measuring
Message 1 of 8
I have questtion how to change text size in  dimension measuring.
All the best !
Michał
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
You can't in the WEB version: maybe in the future.
Message 3 of 8
Thomas_Stuehle
Hello Michael @Anonymous
Welcome to the AutoCAD Web App Forum.
As @pendean said - the function is currently not available. Please compare with the marked solution from this forum post: "Dimension modifications are not accepted".
Could the information provided help you and answer your question?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please don't hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Message 4 of 8
acadhelp1
@Anonymous
Do you have AutoCAD desktop install?  or can get a AutoCAD trial? You could edit the DWG file there and created the desired dimension style, otherwise...
If you only have AutoCAD web, there is a work around if you have a drawing with the desired dimstyle.
  1. With that good drawing, then SaveAs to a new name, like "dimstyles".
  2. Erase everything but the dims using the style(s) that you want to use
  3. Run the PURGE command to get rid of the other stuff
  4. Save this
  5. Open the drawing that needs the dimstyle
  6. Click on the Blocks tab
  7. Click "browse for blocks" and select the DWG you named "dimstyles" in the previous steps.
  8. Insert the DWG
Once you insert the "dimstyles" DWG, you will be able to use the dimension style and apply it to your existing dimensions.  This method can be used to get blocks, text styles, dimstyles, linetypes, or layers from another drawing.  If you need everything, then skip the PURGE step.
Hope this helps,
Jon
Jon Page
AutoCAD Design Manager
Message 5 of 8
Thank You for help !
Message 6 of 8
joe_wetzelZ866G
Observer
Observer
I was looking for a way just to change the scale.  The above instructions was too much work, so I tried something else.  I typed DIM in the command line then hit enter.  Then I typed in Scale.  Then entered my scaling factor.  So glad this worked because all I wanted to do was change the scale.
Message 7 of 8
jillK6SFF
Community Visitor
Community Visitor
Absolutely works and is so easy. You are a genius! Thank you!!!
Message 8 of 8
mark_flynn
Community Visitor
Community Visitor
Awsome.
