Hello @Anonymous
Could the information provided by @mwn help you and answer your question?
Currently using XREF is the way forward.
I just tested with two of the image formats mentioned by @mwn (BMP, PNG, GIF, JPG) and they worked for me. I suggest that they are inserted with a small height/width - I experienced the same on my side. When I checked I noticed that they are inserted with a unit value of 1 for width:
Please try the steps again and zoom in at the location where you selected the insertion point of your image. I suggest that you will find them.
Please select the whole image with a window selection and you will be able to adjust the size afterwards to the size you want.
Did the post helped you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
