AutoCAD on the Web - dimension, units, scale... i need help
Message 1 of 27
hi
starting a new drawing, with metric and decimal precision = "0", i always get 3 digit precision on the DIM command.
how can i overcome this?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (26)
Message 2 of 27
pendean
Community Legend
Community Legend
A flaw you cannot control at this time: you'll have to wait for Autodesk to fix it.
Message 3 of 27
mwn
If you have a drawing with a dimstyle that you want, you can insert a block from it and, if the dimstyle is part of the block, it will be added to your drawing.
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Message 4 of 27
Thomas_Stuehle
Hello @Anonymous
Did the post by @mwn helped you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Message 5 of 27
schweitzerm
@Thomas_Stuehle
The above "solution" is not a solution as someone being forces to teach AutoCAD via the web app due to COVID restrictions in my school.   The fact that you cannot change dimension precision or style is a MASSIVE oversight.  There is no way I can get and explain to my students remotely how to install a custom block.
I am actively looking to remove AutoDesk products from my school district due to the sheer lack of support I have been receiving of the past years.  This is before covid-19 has made it even worse.
Is there seriously no solution to a problem I found within 5 minutes of using your program?
Message 6 of 27
Thomas_Stuehle
Hello @schweitzerm
Welcome to the Autodesk Web App Forum.
Thank you for your heads up. You are referring to the topic above. Does this mean, that you are in the same situation or do you have different conditions?
If this is the case, I just tested the following basic steps on my side:
  1. Create a drawing in AutoCAD Desktop.
  2. Enter DIMSTYLE in the AutoCAD command line.
  3. Edit a dimension style or create a new dimension style with your requirements. On my side I tested with precision = 0.
  4. Save the drawing via SAVETOWEBMOBILE.
  5. The drawing can be opened in the AutoCAD Web App.
  6. Enter DIM to create a new dimension.
  7. Open the properties of the created dimension.
  8. Choose the Dim style that you created and that fits to your conditions.
I recommend furthermore:
  • If the students do not have the AutoCAD Desktop App, create the file for them and share it with them.
  • The students can use your drawing as a template and copy it when they need to create a new drawing.
  • If you do not have access to the AutoCAD Desktop App - you might find the functions in a test installation of the AutoCAD Desktop App (which is valid for 30 days).
I am really looking forward hearing from you about this suggestion.
Thanks & Best regards,
Thomas
Thomas Stühle
Message 7 of 27
schweitzerm
This "solution" is impossible to implement to a room of teenagers who do not know how to use the software.  What kind of "service" is this?
Message 8 of 27
uu1384
Observer
Observer
I don't have AutoCAD desktop, you didn't force me, and I'm not an engineer
It is the most important tool of all
An engineering drawing that has no measurement!? , funny !
Too bad I signed up for a year's plan and lost my money
Message 9 of 27
zipmn909
Community Visitor
Community Visitor
Since these posts go back 2 years should we assume that Autodesk isn't planning to fix? I can't figure out how set units (feet, inches, etc). Also, if I use the "standard" dimension style the text is too small. I can adjust the size by using any of the "Decimal" styles but they display a comma where the decimal should be. What is causing that?
Message 10 of 27
pendean
Community Legend
Community Legend
Your file still needs to be preset for that. in SETTINGS you can only change these
Your file still needs to be preset for that: text STYLEs and DIMSTYLE settings (and options/alternate choices etc.) and more.
Your file still needs to be preset for these many items.
FWIW AutoCADWEB and AutoCADMOBILE are not desktop replacements yet, they remain "adjacent seat" tools, mostly designed to be used for minimal markup/editing and "review". Heavy lifting is still expected to happen on a desktop I believe.
DON'T SHOOT THE MESSENGER 😉
Message 11 of 27
kwolter1005
Community Visitor
Community Visitor
@Thomas_Stuehle  and any other frustrated drafting teacher out there...
In remote and hybrid learning environments, AutoCAD for the Web is a great help.  I'll start by thanking AutoDesk for including access to the web version, as well as the full feature AutoCAD, in their program for schools. The portal for registering a class of students is nearly seamless and it's a pleasure to use the applications for teaching.
With that said, their are shortcomings with working with AutoCAD for the Web. By far the biggest annoyance is that even though precision has been set (to 1 decimal place for example) in the Settings->Units->Precision field, dimensions that are created show 4 places, which causes lots of problems with placing dimensions obviously. The only solution I have for my students is to have them use the Properties->Text Overide field to re-write their dimensions. This is a huge hassle.
So, if there's one thing I'd ask for to be improved upon in AutoCAD for Web, it would be a fix to this problem.
Thanks for a great product, and please continue to support education!
-Kurt Wolter
Rochelle Twp High School &
Kishwaukee College
Message 12 of 27
schweitzerm
We switched to OnShape which has cloud saves and allows me to edit files with students at the same time and access all of their files without any problems.
Message 13 of 27
msgoodrich
Community Visitor
Community Visitor
Why can't Autodesk simply fix this bug?  This problem is a few years old now!?!
Message 14 of 27
pendean
Community Legend
Community Legend
Autodesk does not change anything in the software if not enough people ask for it: do your part to ask/demand over here https://www.autodesk.com/company/contact-us/product-feedback
Message 15 of 27
rbalkemaCVTWN
Community Visitor
Community Visitor
I see some of these posts are quite old.  I just bought this today, if I cant dimension my drawing properly, it is useless.   Does anyone have a fix for this?
Message 16 of 27
pendean
Community Legend
Community Legend
Can you elaborate and be more specific about the issue you are facing please? Everyone can "dimension" in the generic sense of the word all day long in the program
Message 17 of 27
eaCP3Z9
Community Visitor
Community Visitor
How did you get your dimensions to dimension to two decimal places without overriding the text?
Message 18 of 27
pendean
Community Legend
Community Legend
That file was started in desktop AutoCAD with full controls over settings, something the web app totally lacks at the moment.
Message 19 of 27
eaCP3Z9
Community Visitor
Community Visitor
gotcha, thank you
Message 20 of 27
schweitzerm
I did not. I solved this problem by moving to a new web based program.
