I bought a monthly subscription with I TUNES FOR MY IPAD PRO.
MOBILE CAD . DESKTOP -U8E16NG
MK9WDDHJ3 order number.
i had bought with my desktop via ITUNES FOR MY IPAD PRO. DOES NOT WORK . STILL IN FREE APP
HOW TO FIX
MY EMAIL IS MTCHE96@gmail.com
user name CHOI
PLEASE REPLY AND TAKE CARE OF IT .
Solved by Thomas_Stuehle. Go to Solution.
Hello @Anonymous
Welcome to the AutoCAD Mobile forum.
The behavior on your side might be connected with this forum topic: "Accessing mobile drawings online". As mentioned in the solution of this topic, it looks like Apple holds your license and there might be an issue with it: "[...]while you can purchase the mobile apps through Apple, Apple holds the license. So to my best understanding, one would have to buy their own license through autodesk[...]"
When your App is still shown as free, I would recommend to go via Apple to clarify the situation.
Could the information provided help you and answer your question? If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please don't hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Hello @Anonymous
Were you able to make progress on this topic?
As far as I can see there are some open questions. A clarification would help to find a solution:
Which log-in are you using, an Autodesk log-in or your app store's log-in? usually logging out then back in fixes the issue for most users.
If you found a solution in the meanwhile, it would be helpful to document it here for future users with the same or a similar issue.
Best regards,
Thomas
Hello ,
still no luck, contact Apple , ITunes , could not solve the problem either. I have log out, log in, uninstall , install , done almost everything but still in the free app . Apple ITunes will look it into to see if I can get my money back. If not I will continue to bug Apple ITunes .
Really wants to use these in my IPad Pro 11 . Now looking for other apps that can use in my IPad . Thanks for your concern
Hello @Anonymous
I understand your concerns. If a customer has set up the mobile app we can see it in their Autodesk Account. I have emulated your account with the email adress you mentioned and I am unable to see the product in your Account.
As this purchase was made through your App Store we are unable to retrieve any orders. Please contact the Apple Support - I hope these links will guide you to the correct location:
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please dont hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
