How do I change spanish language to english
rsantos225
Observer Observer
rsantos225
Observer
Observer
Hi!
I recently download the AutoCad Mobile app, but I'm from México and it is in spanish. I tried to change my language preferences on the Autodesk profile but nothing happened. Is there a button or configuration page in the app where I can change the language to english? I need to change it  because I learned all the shortcuts and commands in English.
Ty all.
ozkansimge95
Observer
Observer
You should change your ipads language. Then program will change automaticly.
ozkansimge95
Observer
Observer
I have same problem i changed it English but commands still doesnt work... For example i could not find how to extand ... It is really annoying. Why does everything work backwards at Apple?
DzuthonoTunyi
Hi @rsantos225
If the requirement is to change only the language for the AutoCAD mobile app, try the following:
  • Settings > Apps > AutoCAD > Language > Select your preferred language.
Note: If the language change does not take effect immediately, close and restart the AutoCAD mobile app to apply the new language setting.  Hope this helps!
Dzuthono Tunyi
Technical Support Specialist
If the solution I shared did the trick, feel free to mark it as “Accept Solution", it helps others in the community find answers more quickly.
