AutoCAD - DWG Viewer & Editor Tablet application font issues
connor6JASB
Observer Observer
connor6JASB
Observer
Observer
I have installed the above for a tablet so us who work here can access .DWG files when not near a laptop, however the symbols have completely changed compared to the Windows applications.
Has anyone experienced the same/similar issues? if so does anyone know if there is a fix for it.
It is a Samsung tablet, the app installed is the AutoCAD application from the google play store: AutoCAD - DWG Viewer & Editor – Apps on Google Play
For example:
It is now showing n instead of a radius symbol, v instead of a counterbore symbol etc.
manieshkumar.suresh
Check out this article - Tolerance dialog box displays letters instead of symbols in AutoCAD
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
paullimapa
May want to post this on the mobile forum to get better feedback
https://forums.autodesk.com/t5/autocad-on-mobile-forum/bd-p/autocad-on-mobile-forum-en
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@connor6JASB Are you asking about AUTOCADMOBILE online cloud app, or WEB app, and your "tablet" is running iOS or ChromeOS?
1) you're in the wrong user support forum, that is way over there https://forums.autodesk.com/t5/autocad-on-mobile-forums/ct-p/autocad-on-mobile-en I'll ask the admin to move your post once you reply back.
2) All of your fonts need to be uploaded to that cloud too as explained here https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Uploading-SHX-font...
@manieshkumar.suresh
pendean
Community Legend
Community Legend
@connor6JASB Read this https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Uploading-SHX-font...
if these are TTF fonts that are needed, you are just out of luck today in January 2026: you'll need to change the font in desktop AutoCAD first to an SHX font for your text symbols.
rosie_lucas1
Hello @connor6JASB,
Just checking in—did the responses shared by @pendean and @manieshkumar.suresh help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie | Community Manager
santosh731994
Community Visitor
Community Visitor
For example:
