AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
Editing dimension lines is not possible
7 REPLIES 7
Message 1 of 8
655 Views, 7 Replies
Hello, I have the AutoCAD application installed on the iPad, I canceled the license for one year, but it does not allow me to edit the lines, in the properties box the dimension appears but it is deactivated. It is feasible to correct this situation.
@Anonymous:
This article was automatically translated by @Thomas_Stuehle due to the English forum. Previous content: Edicion - Hola tengo instalada la aplicación de AutoCAD en el iPad, cancele la licencia por un año, pero no me permite editar las líneas, en el cuadro de propiedades figura la dimensión pero esta desactivada. Es factible corregir esta situación.
7 REPLIES 7
Message 2 of 8
Thomas_Stuehle
Hello @Anonymous
Welcome to the AutoCAD Mobile Forum.
Are you able to provide a screenshot of the situation you face? This would make the issue a bit more visible.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Message 3 of 8
lena.talkhina
Hello @Anonymous !
Welcome to Autodesk Community. Great to see on Community forums.
Are you aware of existing Spanish community? If it's easier for you to communicate in Spanish, don't hesitate to click the link.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 4 of 8
in reply to: lena.talkhina
I have the same issue on my Google Pixel Book (Android). When you click in the box to edit the dimension the number pad at the bottom of the screen grays out the numbers so you can't select them. Screenshot 2020-12-01 at 8.14.12 PM.png
Message 5 of 8
Thomas_Stuehle
Hello @Anonymous
Editing text of dimensions is currently not supported. The alternative workflow is to select the dimension and to edit the vertex of the dimension.
Did the post helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Thomas Stühle
Message 6 of 8
in reply to: Thomas_Stuehle
Hey @Thomas_Stuehle Thanks for the reply. This is happening when I am drawing a line. Sorry I may have chosen the wrong thread.
Like on the web app you can draw a line and instead of having to draw you it you can type the angle and the length in, but on the mobile app this is not allowed. Is this broken or the way it is currently designed?
Message 7 of 8
Thomas_Stuehle
Hello @Anonymous
On my side I can enter the length of the line. Regarding the angle I need to check further. Please let me know the following points:
  1. Are you on an Android or iOs device?
  2. Which version of the Mobile App do you have installed?
Thomas
Thomas Stühle
Message 8 of 8
@Thomas_Stuehle The app is version 4.6.10 on a Google Pixel Book running Android version 9 (R86-13241.99.0)
