AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
Autocad mobile cannot be used.
3 REPLIES 3
528 Views, 3 Replies
Autocad mobile cannot open files from Autocad 2020. However, updates cannot be installed.
Why does a file always have to be uploaded first and cannot simply be started from the hard disk? For me the AutoCad mobile is completely worthless
@Anonymous
The post was translated by @Thomas_Stuehle due to the English language in the forum. Original post:
AutoCAD mobile nicht nutzbar. Autocad mobil kann Dateien von Autocad 2020 nicht öffnen. Updates können  aber nicht installiert werden. warum muss eine Datei immer erst hochgeladen werden und kann nicht einfach von der Festplatte aus gestartet werden? Für mich ist das AutoCad mobile dadurch völlig wertlos
3 REPLIES 3
pendean
AutoCADMOBILE is a could based app: as in, it is not on your computer https://www.sumologic.com/glossary/cloud-application/#:~:text=A%20cloud%20application%20simply%20ref....
HTH
Thomas_Stuehle
in reply to: pendean
Hello @Anonymous
Welcome to the AutoCAD Mobile Forum.
I suggest the functions that could help you are SPEICHINWEBMOBIL (Engl: SAVETOWEBMOBILE) and ÖFFÜBWEBMOBIL (Engl: OPENFROMWEBMOBILE).
When you press the buttons in your AutoCAD 2020 application a window pops up which lets you save them directly in your File Manager. You will see the files straight away when you open your AutoCAD Mobile App or AutoCAD Web App afterwards.
A manual upload is not needed. The situation changes when you talk about the Autodesk Viewer (viewer.autodesk.com). In the viewer a manual upload is required.
Did the post help you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Hello @Anonymous
Did the posts above help you and answer your question?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please dont hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Thomas Stühle
