I have created a folder in AutoCAD 360 and uploaded a dwg drawing. However, when I open Autodesk from AutoCAD I can see and open the folder but cannot see the drawing file.
Mike
When I select File > Open on the left hand menu I select Autodesk 360 to view the folders on my Autodesk account. I can generally see files I have uploaded and open them. However, for some reason, I cannot see the latest drawing I have uploaded. I will try and paste a couple of screen shots.
Wow! That is a bit confusing!
I'm happy to upload the drawings outside of AutoCAD but want to open the file from AutoCAD on my laptop.
My company is a world wide organisation and I want to allow access to machine blocks to a cloud library so they always have the latest drawing.
When I started to look at it the Autodesk 360 short cut on my menu seems to link to a synchronised FTP(?) I expanded and collapsed it and when I went back to my AutoCAD I could see the drawing file!
I will work with it a bit more. When you initially open the short cut the response seems quite slow. Once you are in the cloud folders it's fine.
Thanks for your help.
Mike
