SwitchBack with BIM360? can I?
tech3design
tech3design
can I use switch back with BIM 360 ??
Revit 2016
Navisworks 2016
or
Switchback with Glue.??
Thank you,
Replies (7)
james.l.bryant
Hello @tech3design,
Thank you for contacting Autodesk Support.  This inquiry is being reviewed under case # 13186528 as per this forum entry.  A representative will be assigned to answer your question.  Thank you
James L Bryant
Autodesk Support Team
Contact Autodesk |
tech3design
Any luck, I still can't do my switch back.
Can you help with another solution? or alternative way to find my clashes with out going have to look for the same item for minutes at a time.
Thank you,
james.l.bryant
This discussion has been replied by Autodesk representative via case # 13186528 at this Forum post.
James L Bryant
Contact Autodesk |
Adam.CookAVT
Observer
Observer
I've just figured this out this morning.
Since BIM360 doesn't create a traditional local file it appears as though there isn't one, BIM360 does create one however, not under the same file name.
This is hidden within "App Data";
File path would be something similar to this - C:\Users\Home PC\AppData\Local\Autodesk\Revit\Autodesk Revit 2020\CollaborationCache\
You would have a project folder which would be a random sequence and then RVT Project files which would be your local file. Hopefully this helps.
smurck
That does'nt work.  I would like them to answer this question:  Does switchback work with BIM 360?
Michael.Fernandez3ZHS6
I too am also waiting to hear the anwser. Whenever I try to use BIM 360 with switchback, it works up until the point where I refresh the navis model after having changed some things in revit.
fperaltaDE93G
This worked with BIM360, thanks for the tip!.  (I know is an old answer)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
