Simply cannot disable F1 help key
rodrigo_luizp
rodrigo_luizp
I already read all the posts about disabling the F1 macro but still no luck.
I cant find any connection to the F1 key to the _.help command on the CUI Menu.
Under Keyboard shortcuts/Shortcuts Keys i createad a command to run ^C^C._dist when F1 is pressed.
My output on console look like this:
<When i Press F1>
OUTPUT:
Command: '_.help
Command:
Command:
Command: ._dist
I tried changing the macro '_help from the commands list Help. even tried to deleted but not change.
I cant find f1 macros anywhere that are sending '_help.
Can anyone help me?
s.borello
What happens when you type command "help" followed by return?
rodrigo_luizp
It opens the help menu.
Command: HELP
pendean
Community Legend
Community Legend
F1 is a WindowsOS function call to HELP files in almost every program on your PC, even your webbrowser.
rodrigo_luizp
I know but im a macro key afficionado and want to use every key on my keyboard my way.
The thing is, my macro works on Autocad 2018 just fine, this macro just doesnt work on Autocad 2019 MEP.
