AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Programmatically Change MEP Services
3 REPLIES 3
dustin.lambert
497 Views, 3 Replies
dustin.lambert
I'm seeing if there is a way to programmatically change services with MEP parts. Ideally, I'd like to find a way for the user to simply type in a command which allows them to select a service, once the service is selected it changes from one service to another (in this case from the "new" service to "existing". Not finding a way to programmatically change services though.
3 REPLIES 3
Gepaha
in reply to: dustin.lambert
Gepaha
Can you explain further which MEP Services you are referring to?
dustin.lambert
in reply to: Gepaha
dustin.lambert
My initial comment could be a confusing as we call them "Services" at work but in CADMEP they're "Systems"
andkal
andkal
It is possible to change System with Lisp.
Example here:
http://autolisps.blogspot.com/p/matchductpipesystem.html
Maybe you will find something in the code that will help you.
This lisp matches System property of selected MEP objects.
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
Example here:
• Autodesk AppStore
