In need of some assistance im trying to export an IFC file and i get this error. Any idea what can be happening ?
[DefaultDomain: ]EXPORT STARTED: 10/17/2016 11:00:19 AM
[DefaultDomain:Error]External component has thrown an exception.
at cppw.Open_model.create(Open_model* , Application_instance* , String* )
at Autodesk.Aec.Ifc.FrameWork.FwFaceSet.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwBrepShell.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwRepresentation.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwRepresentationMap.Generate()
at Autodesk.Aec.Ifc.Interop.OpProxy.CreateCachedObjectForExport(IKey key)
at Autodesk.Aec.Ifc.Interop.OpProxyExportCacheManager.GetCachedObject(IKey key, ICacheableFactory factory)
at Autodesk.Aec.Ifc.Interop.OpProxy.Export(Boolean generateFwObject)
[DefaultDomain:Error]OpProxy aborting operation...
[DefaultDomain: ]
Object Count:
- AcDbBlockReference : Total: (5700)
** = Object classified as other IFC object.
[DefaultDomain: ]EXPORT ENDED: 10/17/2016 11:03:16 AM
Solved by Victoria.Studley. Go to Solution.
Hi @rgilbim,
Thank you for posting your question here. Could you post a copy of the drawing file where you're encountering the error? I'll be happy to take a look.
Does the file contain any non-Autodesk content?
Have you tried repairing the file?
Attached find the file im trying to convert.
Tried everything suggested even purging and auditing it.
Thank you for posting the file, @rgilbim.
When I first open the file, I get the "Foreign DWG" message:
This indicates the drawing was created/saved by a non-Autodesk software. Which program did you use to the create your file?
This is likely the cause of the error, and you may need to address the root cause of the issue in the third-party application that created or modified the file.
