- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In need of some assistance im trying to export an IFC file and i get this error. Any idea what can be happening ?
[DefaultDomain: ]EXPORT STARTED: 10/17/2016 11:00:19 AM
[DefaultDomain:Error]External component has thrown an exception.
at cppw.Open_model.create(Open_model* , Application_instance* , String* )
at Autodesk.Aec.Ifc.FrameWork.FwFaceSet.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwBrepShell.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwRepresentation.Generate()
at Autodesk.Aec.Ifc.FrameWork.FwRepresentationMap.Generate()
at Autodesk.Aec.Ifc.Interop.OpProxy.CreateCachedObjectForExport(IKey key)
at Autodesk.Aec.Ifc.Interop.OpProxyExportCacheManager.GetCachedObject(IKey key, ICacheableFactory factory)
at Autodesk.Aec.Ifc.Interop.OpProxy.Export(Boolean generateFwObject)
[DefaultDomain:Error]OpProxy aborting operation...
[DefaultDomain: ]
Object Count:
- AcDbBlockReference : Total: (5700)
** = Object classified as other IFC object.
[DefaultDomain: ]EXPORT ENDED: 10/17/2016 11:03:16 AM
