Copy With Base Point Not Working
vmusser
vmusser
Community Visitor
Community Visitor
I am having trouble with the "copy with base point" and "paste". I have never had trouble with this before, but on the drawing I'm working on most of the time it does not work. I use the copy with base point command and when I go to paste, nothing shows up. It does work sometimes, most offten when I try it the first time after opining AutoCAD, Then when I try it agian it does not work. Can you help me?
Vernon
Victoria.Studley
Hi @vmusser,
Thank you for posting, and I'm sorry to hear you're experiencing this issue. Which version of AutoCAD MEP are you using?
First, here are some common causes for copy/paste behaving this way, and suggestions to help you fix it.
If the issue started happening this week, I'd like to know if you've installed any of this week's Microsoft Windows updates. If so, the issue could be caused by one of these, and I can help you narrow it down. Please let me know, and I'll be happy to help you.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @vmusser,
I'm checking in to see if you need further assistance with this issue, or if you've found a resolution. Please let me know if you need more help, and I'll be happy to continue assisting you.
Victoria Studley
I have the same problem. I have installed update for Office today, I have uninstalled later but still not working
christophe.legrand
I have this problem sometimes. I can't solve it but i find something.
- Open a new drawing
- Add your problem file as a xRef
- Link it as a block
- Explode the block
- Normally it's right 🙂
Christophe Legrand
r1034291
Community Visitor
Community Visitor
Base werkt niet
r1034291
Community Visitor
Community Visitor
base werkt niet
