Air Terminal Grille mounted direct on duct side
marco.defina
Message 1 of 8
marco.defina
it's possible to mount an Air Terminal Grille direct on Duct side without a joint?
Example:
Attached drawing.
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Replies (7)
Message 2 of 8
VitalyF
Try to use the command "OBJECTANCHORATTACH" to your mvpart.
See attachment:
MVPartAnchor.avi
Good luck,
Vitaly
Message 3 of 8
marco.defina
OK, but so don't take the information of the grille (ex. Flowrate), it's only an anchorage...
Message 4 of 8
Keith.Brown
In order to read the flow rate you will need to create a special tap fitting that has a length of .0001.  You will then need to place this special tap fitting and then attach your mvpart to it.  That way you can physically and logically create a connection between the mvpart and the duct.
In general you should do this type of workflow all the time when working with ductwork as the systems want/need to be connected logically especially if you are using the sizing tools.
Message 5 of 8
marco.defina
Ok, with your indication i tried a possible solution with the standard parts.
I opened the content generator to modify the Aecb_Rectangular_Duct_Takeoff
I changed the parameter of the lenght, so that i can select a personalized lenght (the same of height and width)
After save i return in my drawing and i can change the lenght from 0 to x
This is the result
Message 6 of 8
Wow, nice job. I've always struggled represting this as well. Thanks!
Message 7 of 8
harryliu3140
Curved grille attach to a round duct work is not possible. the length of the fitting can't be negative.
Message 8 of 8
harryliu3140
This is what I mean.
