Paperspace printing issues
steve-NEO
510件の閲覧回数
4件の返信
メッセージ1/5
steve-NEO
I have a file that has both geometry in the CAD file and attached x-ref files. When I am in paper space mode, I can see everything on my monitor fine but when I do  print preview and or print, my xref files are not shown just the work from this file.
If I try printing from my old workstation (AutoCAD 2012) everything is fine.
I am using Acad 2015 Mechanical
Windows 7 64bit
Everything is up to date software wise
This is a fresh install on a fresh computer ....ie.... no "old" data. I have set up everything from scratch everything from scratch and have not carried over 1 single piece of "old" AutoCAD set up data other tham opening files that are already existing.
0 件のいいね
511件の閲覧回数
4件の返信
返信 (4)
メッセージ2/5
VinodBalasubramanian
Autodesk Support
Autodesk Support
Can you check the following,
https://forums.autodesk.com/t5/autocad-2007-2008-2009/xrefs-not-plotting/td-p/2351484?nobounce
If it doesn't work, can you please post a sample drawing for us to investigate.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
0 件のいいね
メッセージ3/5
Autodesk Support
Autodesk Support
Good day to you.
Just wanted to check with you for an update. Please let us know, if you need further assistance.
We will be glad to assist you further.
Your understanding and support is greatly appreciated. Have a great day !
0 件のいいね
メッセージ4/5
Autodesk Support
Autodesk Support
I would like to follow up again to see whether you still need help on the plotter issues. Do let us know. We will be more than happy to help here.
0 件のいいね
メッセージ5/5
steve-NEO
Hello everyone. I managed to fix the problem. Here is what I did.
First, my customer uses Siemen FactoryCAD. There are a series of blocks that they use for general equiptment layout that come from this.
I contacted Siemens and they have a series of "CAD enabler files" that I had to install next to AutoCAD. Basically the block set needed to just get the .dwg files to open. They seem to be behind Autodesk in that they only have these "enabler files" available for 2015 and not 2016 (I was trying to use the latest greatest software in 2016 and could not). Without this nothing xref'd would print.
Once I installed these enabler files, all my xref problems went away.
Thank you for your suggestions and time everyone!!
----Steve
0 件のいいね
