Hi @Anonymous,
It sounds like you have plain AutoCAD installed, or are running AutoCAD Mechanical as a Vanilla profile.
Check the profile being used in OPTIONS under the Profiles tab. If you see <<ACADMPP>> and <<Vanilla>> you have Mechanical running. Try setting <<ACADMPP>> as current and check the workspace. You should see the Mechanical Workspace at the to top of the list.
If you do not see <<ACADMPP>> in the profiles, this is likely plain AutoCAD and Mechanical will need to be installed. You can do so from your Autodesk Account.
Please let me know if this helps.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider
Liking the post.
