How to split text above and below the dimension line
mikec
mikec
hello all. I am wondering how I make my dimension look like    2.249"  top dimension and bottom dimension
        2.245"
Can anybody help me?
Thank you,
MIke
[The subject line of this post has been edited for clarity by cheryl.buck from: split dimension ]
cheryl.buck
Autodesk Support
Autodesk Support
Hi Mike (@mikec),
One way that text can be split above and below the dimension line by adding \X where you want the break. Note, it must be a capital X.
Please let me know if this answers your question.
All the best,
If a post was helpful, Likes are always welcome.
Please Accept As Solution any post(s) that answer your question or solve the problem.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @mikec,
I am checking back to see if my post helped you with your problem.
Please post an update letting the community know if you were able to resolve the issue.
All the best,
Cheryl Buck
greg.youngCXLLN
Hi Cheryl, is there a way to adjust (increase) the Text offset? When doing this?
Cheers
tmboyd-corraliza23
Observer
Observer
This thread is sooooo wrong and it just messed me up so it needs to be fixed right now. It's <>\X not JUST \X
martynLAWNG
Thanks, that worked perfectly
patrick_austinARMYQ
Community Visitor
Community Visitor
I found this post helpful. I always forget the capital X!!!
