how to select all the objects in a layer
Message 1 of 14
How do I select all the objects in a layer without selecting each object in the layer one by one?
thanks
Accepted solutions (3)
Replies (13)
Message 2 of 14
Following are two ways you can do this.
1. In the drawing space, right-click on empty space to get the context menu.
Select "Quick Select". Using the "Layer" option in the Properties list, all
the objects in the layer specified will be selected.
2. In the AMLAYER, Layer tab, highlight the layer name you want and click on
"Selection Set". After exiting the dialog box, the selection set is
"remembered". To use the layer as the selection set, use Previous during
selection.
Jul-Vie Siew
Product Designer
AutoCAD Mechanical
wrote in message news:[email protected]...
thanks
Message 3 of 14
You may also try the FILTER command.
Regards
Wu Tao
"RMIRZA" wrote in message news:[email protected]...
thanks
Message 4 of 14
You can also use LISP at the command line to get it...
(ssget "X" '((8 . "YOURLAYERNAME")))
Then invoke a command and select P (for previous).
Message 5 of 14
rornelas
A fifth option is to use the "Layer Isolate", then select everything.
Message 6 of 14
I should use Quick Select in the Properties-dialog...
Cheers
Rikard
Message 7 of 14
Unfortunately the other layers are on the top and the one that I need is under them. It doesn't let me show the one under that I need and I don't want to change the order of all the layers. Can't I just choose all the stuff that are on that layer so that it selects them right away?
Message 8 of 14
mark.kauhanen
AutoCAD feels very rudimentary once you use Rhino... Selecting all objects on one layer should just be a Right Click away on the Layer.
I feel Selecting objects, in general, is not a strong suit of AutoCAD.
Message 9 of 14
pendean
Community Legend
Community Legend
>>>... Selecting all objects on one layer should just be a Right Click away...<<<
@mark.kauhanen SELECTSIMILAR is right there as you desire: just control the parameters with SELECTSIMILARMODE for your desired always-active settings or LISP it to automate.
Message 10 of 14
ds2274
100% accurate. I had to switch back to ACAD for a job, and I'm having Rhino withdrawals, things that were a click away are now the bulk of the time spent on a given project.
Message 11 of 14
alexandre.alvrz
Observer
Observer
Yeah, Rhino is an absolute machine when it comes to work intuitively. I have to use autocad at work and i'm astonished how everything is so complicated, literally the whole software is awful and time-consuming. I really can't understand why schools ask students to start drawing with it. I mean rhino for students is worth 200$ and you have it for life AND is better in every way. Autodesk should delete this software asap, it would be life changing 🙂
Message 12 of 14
oleg.bykh
Community Visitor
Community Visitor
Truth.
Message 13 of 14
temeddixMC5KM
Agreed, but we all know that Autodesk just focuses on maintaining monopoly... without the actual improvement of the software..
I've been using Rhino and have been wondering while Autocad is still dominant in 2023. Perhaps it's because of its huge marketing sector, but who knows.
Message 14 of 14
kadscad
Microstation has a toggle Level lock. Which licks all levels except the active level aka layer
Not to be confused with locking a layer in the layer manager
Kirk
Inventor 2023
